Spray on/brush on electrical tape, any good?
Postby dh » Mon Sep 13, 2010 4:13 pm
Anybody used this stuff? Is one better than the other? I have some joints where heat shrink is not feasable and am considering this stuff.
dh
Postby madjack » Mon Sep 13, 2010 4:30 pm
I keep a can of the brush on in the shop...useful for lots of stuff...you may wish to use 2/3 coats to ensure good/total coverage...tuff stuff, once cured it's there forever.......
Postby starleen2 » Mon Sep 13, 2010 6:26 pm
any particular brand that you use - never heard of the stuff :scratchthinking:
starleen2
5th Teardrop Club
Postby madjack » Mon Sep 13, 2010 6:29 pm
...whatever they sell at my local ACE Hdw...I believe the brand name was Starlite...maybe............. 8)
Postby Lgboro » Mon Sep 13, 2010 7:54 pm
I have used a couple of different brands and have had really good results with both. Any hardware store should have the stuff as well as WalMart around here. Have had almost 0 trouble with my lawnmower trailer lights and especially my flounder lights since using the stuff. Comes in several colors too if you are so inclined.
Lgboro
Images: 53
Postby dh » Mon Sep 13, 2010 11:12 pm
Thanks for the replies, Looks like I'll be picking up a can on the way home tonight :thumbsup:
dh
Postby Nobody » Tue Sep 14, 2010 8:06 am
Just make sure you let it 'cure' thoroughly! A couple or three light coats with plenty of time to cure between coats. If it doesn't cure completely it'll 'crack' if there's flex at the joint. Once cured, that stuff is there to stay :thumbsup:
Harvey -
Nobody
Images: 342
Postby dh » Tue Sep 14, 2010 10:48 pm
Nobody wrote:Just make sure you let it 'cure' thoroughly! A couple or three light coats with plenty of time to cure between coats. If it doesn't cure completely it'll 'crack' if there's flex at the joint. Once cured, that stuff is there to stay :thumbsup:
I learned that the hard way last night. I tried to goop it on, it didn't want to dry and I ended up taking it all off with lacquer thinner and starting over with thin coats. The can says 5 min between coats, but it still looked wet, so I let it sit for 20 between coats. This afternoon it loked good. I'll have to see how it looks tonight when I get home. Says it takes 24 hours for the stuff to cure.
Just a side note, I soldered a T splice for the trailer brakes (12G wire). I couldn't get my little soldering iron to get the joint hot enough, so I ended up using the propane torch to solder the joints. It worked a lot better than I thought it would :thumbsup:
dh
Postby dh » Tue Sep 14, 2010 10:52 pm
I almost forgot. I originally saw this stuff at evil-mart, in the automotive section. I went to get some last night, but they where out of the brush on, so I grabbed a can of spray on. I happened by the marine section in sporting goods, and they had the brush on there, just a different brand, so I grabbed it.
dh
