by vreihen » Sun Oct 10, 2010 12:39 pm
Is that connector a standard flat 4-pin trailer light plug? If so, someone may have cobbled the round (7-pin Bargman?) plug onto a trailer wired for 4-pin lights. My guess is that the 5th wire (heavy gauge yellow) is either for brakes or more likely for charging the trailer's battery from the tow vehicle.
If I'm right on the above, the 4-pin plug may come in handy if you ever want to tow that trailer with a vehicle that isn't wired for 7-pin. Just split the 4-pin connection, and plug the trailer side into the tow vehicle's 4-pin connector. Of course, you won't get battery charging like that.
My $0.02 is that if that white wire is the ground, it is obviously too short (which caused the wire to stretch and pull out of both halves of the connector). It is also severely under-sized as a trailer ground if the heavy yellow wire is +12V for charging the trailer battery. Some people think that they can get away with no ground because the hitch ball and safety chains conduct electricity, but both are moving pieces that lose contact over bumps. I would pull a new ground wire from the 7-pin Bargman plug all the way to wherever the white wire ends on the trailer, and make sure that it is at least the same size as the heavy yellow wire. I would also make sure that whatever wire grounds the negative battery terminal to the trailer's frame is not as thin as the white wire, just to be sure. You can probably get away with just putting some liquid electrical tape or some sort of non-conductive RTV sealant over the exposed wires if they still work, since they are only grounds and not a short circuit risk if they hit the frame.
Of course, my disclaimer that I'm not an electrical engineer or electrician is required here.....
