I have the remote temp. probe and the meter. The meter shows two temperatures - the temp at the controller and the remote temp. I bought the remote temp probe after I noticed more than 10F difference between the two values, even when I knew they should be within a degree or two. The readings settled down after I installed the probe and started showing more realistic numbers. The probe isn't a must have item but it will result in the best battery charging voltages. I waited to buy one till my wallet wasn't so empty and I'd found the best deal I could.
Warning! Having the meter is a nerd test. If you spend more than a minute watching the solar output in real time, you might be a nerd.
Bruce (Yeah, I failed the nerd test)
P.S. The controller has a load terminal where amperage is logged so you can monitor the amp-hrs going to a load. Its only a 15 A output but you could use it to track your energy usage if you can get most of your loads routed through it. It also disconnects the load when the battery voltage gets too low.
I use one of these to track my amp-hrs -
Trimetric TM-2025-RV. Between the Trimetric and the Morningstar, I can track amp-hrs in and out of the battery and the PV panel performance. Its like having an instant battery gauge. Much more accurate than using a voltmeter.
