I read everything I could find here and didn't see this. Any help appreciated.
Harbor Freight has an Inverter they sell for approx $129. I have a 5x8 Cargo Trailer that has a 4.4 cu ft Refer/freezer on board. Max watts used is 190. When on the road I would like to run the Refer with the HF (?) inverter powered by the TV's 12v system. My question is: given the load, 190 watts max, 110v AC. would the inverter place too big of a load on the T.V.'s 12 V system? Would this be a reasonable application or a pipe dream?
When parked I'll use shore power or a 1500 watt generator. I'm not planning on having a 12V battery in the CT I'm planning on using a WFCO 8725 to distribute the 110 & 12Vwhen parked. 12V will just be used for lights.
My inexperienced hunch says this should work. Please help me figure out the downside. Thanks.... Jeff
