by eamarquardt » Sun Jan 16, 2011 10:31 pm
Running items designed for household use off a battery and inverter while camping for extended periods is the "height of optomism". You can't get 100 amp hours from a 100 amp hour battery. Depending on the design maybe 50 to 80 percent of the 100 amp/hour rating. In addition you shouldn't draw or charge at more than 10 percent of the battery's capacity at a time. So for a 100 amp/hour battery that's 10 amps or maybe (factoring in the efficiency of the inverter) 100 watts or so.
Running a 1500 watt hair dryer, a 500 watt heater, microwave, refrigerator, or similar unit is simply not practical without a huge battery bank. In addition, once you use the "juice" you have to put it back into the battery before you do it again. How do you plan on recharging your battery?
If you need that kind of power a generator makes sense but they are expensive, noisy, and you don't want to run all the time for a refrigerator.
Look through my posts or do some searches for more on this topic.
Gus
