led wire size/fuse
led wire size/fuse
Postby 3822sean » Tue Feb 08, 2011 12:47 am
:thinking: hello everyone im putting all led lights on or in my teardrop and i was reading through sdtripper2's index about wire size and fuse sizes found some very cool stuff,,,but on led's should i still use 16ga wire some of the led's come with wire pretty small stuff im guessing 22ga, would it be ok to use the same gauge or should i use the 16 ,,,,one more i dont know the watts or amps cant imagine they are very big,,,the chart i saw in the index only went down to 16ga when it came to choosen a fuse size. maybe 7.5 amp for 22ga thanks ahead of time this is a very helpful sight for :thumbsup: somebody building their first tear
3822sean
Images: 37
Postby eamarquardt » Tue Feb 08, 2011 12:59 am
Here are some applicable web sites:
http://www.rowand.net/Shop/Tech/WireCapacityChart.htm
http://www.powerstream.com/Wire_Size.htm
You need to know how much your lighting will draw to determine the correct wire size and fuses/circuit breakes to use.
Gus
eamarquardt
Images: 150
led amps
Postby 3822sean » Tue Feb 08, 2011 1:25 am
i just found this on the net 1.2 volts x .025 amps = 0.03 watts per bulb does that sound right :?
3822sean
Images: 37
Postby eamarquardt » Tue Feb 08, 2011 1:45 am
That's part of the equation but you need to get to 1.2 volts.
Here is another good site with a resistor calculator and other techniques for getting things right.
http://www.llamma.com/xbox360/mods/How% ... %20LED.htm
Gus
eamarquardt
Images: 150
leds
Postby 3822sean » Tue Feb 08, 2011 2:08 am
thanks gus for your help trying to wrap my head around it thanks again
3822sean
Images: 37
Postby H-Balm » Tue Feb 08, 2011 5:43 am
Here is what I learned that is the most important.
I cut it from another site I found, that deals with auto electric.
1. Calculate your wire size attached to the fixture (many come with a few inches of connection wire).
2) Use the following table to determine the maximum current for whatever wire gauge is being used.
3) Take the maximum current value obtained from the table and find the largest fuse you can find that still falls within the limitations. DO NOT EXCEED THE VALUES ON THIS TABLE! Common automotive blade-style fuses exist at 5A-20A in 5A Increments. Ex: 5A,10A,15A,20A
Determining the Total Amperage of your Circuit
Current is measured in Amperes, abbreviated to Amps or just the letter A. Because of the low-current nature of LEDs, many have current listed in milliamperes (or mA for short).
1A is equal to 1000mA
To find the total amperage in your specific installation, refer to the table below. Find the items that you are installing and their current requirements. Add the values and divide by 1000 to get your total current in Amps. You can use this value in the table above to determine the minimum wire size required.
Here's an example.
Say you bought a cold cathode kit for each side of the dash (2 Transformers), 5 superflux LED's for your vents, and a 4.7" Flexible LED strip for your center console.
If you want to put all of these on a single circuit, you'll need to know the current. Based on the table above, each transformer draws 700mA, each Superflux LED draws 80mA, and the LED strip draws 80mA
If you add up (700*2)+(80*5)+(80*1) you would get 1880mA total.
Divide this by 1000 to come up with 1.88A.
Put 1.88A into the top table in this post. That table tells you that you should have no smaller than 21 gauge wire for your circuit.
Personally I would go with the 20 gauge wire and a 2.5A fuse.
H-Balm
Postby Shadow Catcher » Tue Feb 08, 2011 7:08 am
You should probably also think conservatively and go with a wire size that is bigger than you need to prevent line loss and for future needs.
Postby H-Balm » Tue Feb 08, 2011 5:11 pm
Also, fuse is based on the wire gauge.
Think of the wire/fuse as a bicycle lock.
A really big lock (the fuse) won't help you, if your chain (the wire) is weaker.
Many people think the fuse is a invincible shield, that stops all problems.
Wire size must be examined.
H-Balm
Postby TwilightLane » Mon Feb 28, 2011 10:45 pm
I like this calculator: http://led.linear1.org/led.wiz
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby Dale M. » Tue Mar 01, 2011 11:53 am
Forget all the calculators use 16 gauge minimally and if in doubt use 14 gauge.....
Sleep well...
Dale
Dale M.
Images: 18
Postby Dale M. » Tue Mar 01, 2011 11:56 am
H-Balm wrote:Also, fuse is based on the wire gauge.
Fuses are bases on current flow! (assuming on proper wire gauge) ...
Dale
Dale M.
Images: 18
