frank_a wrote:I looked at a lot of the A/C stuff on the site Gus, and it seems for ease of use, noise, size, and convenience of placement, pet cool is the way to go. Not only does it heat and cool, it dehumidifies, which folks with the $100 A/c units (mostly around 5000 btu) seem to have problems with in muggy heat, which we get around here.
I'm more than open to suggestion, but I'd like to have a good all-around unit that would work as well in northern Quebec or Florida. Pet Cool just looks easy to do.
Frank
All a/c units dehumidify. The "trick" is to use a unit that isn't too big. If you use an oversized unit, the air isn't cycled over the evaporator (cooling coils) enough times to condense the water vapor. Several folks have modified window shakers to be as convienent as the pet cool.
I agree that having the unit sit on the deck, not attached (except for hoses to duct the air) to the trailer so that noise and vibration are minimized is the way to go. I don't sleep well at night when the forced air heater in our house cycles on and off (fortunately we don't need to run it at night). It's cool enough here that I haven't run my home air conditioner but half a dozen times in the 27 years I've been in this house and we have never needed it at night.
So. Cal. has it's advantages (but government, taxes, and congestion aren't among them!).
Your "argument" that it pet cool is convienent is valid but with a little effort you can achieve more "cost effective" results.
Gus
