OK, So I'm looking at inverters. The reason it easy... I'm not getting a converter. I see no reason to. My lights are 12V LED's and have transformers with them and everything else has bigger draws... I thought it would be simpler and cheaper to just wire everything of a 120V inverter.
But then I saw an inverter/charger. Looks cool, but it's no longer available from Norther Tool. I know I want to pull a wire from my car's alternator to the battery's to charge while running... but I'm not certain if the inverter will switch to shore power automatically or if there are switches needed. And this one had a charger to start charging batteries when shore power is available.
Is the 'all in one' idea best or separate components better? I usually think separate because WHEN something fails your not totally screwed, only half screwed... but how do you guys do your inverters? How are switches from shore power to battery handled, and how about chargers... separate or built in.
Lastly, there are TONS of new solar products replacing inverters right now. They don't do stepped charging but are "trickle" and that does not sound good for my 'El-Cheap-O' brand battery, but would a solar kit be fine if the switches from shore power to battery are expensive or just plane difficult. The solar options bug me because you need a 15AMP panel and that's just pricy...
I'm just about to spend money and having second thoughts about how to best do this. Just need some reinforcement.
Thanks!
