Tall order but I know you know more than I know.
NCOretiredEd wrote:3000 w min, for quietness, durability, lightness and price.
TPMcGinty wrote:NCOretiredEd wrote:3000 w min, for quietness, durability, lightness and price.
The nice quiet, durable, and light generators are NEVER cheap. A Honda generator will get you 3 out of 4.
madjack wrote:...first, a couple of question for you...do you actually need 3000watts, that is generally a WHOLE LOTTA POWER in a camping generator...most folks get by with 2000w quite nicely and where are you going to use it...,if boony camping by yourself, you can get by with a noisier generator than if camping around others.......
...with what I stated above in mind, the price you quoted will not be for a quiet generator...which may be OK if your are camping alone and don't mind the noise...here are two examples of quiet generators...the first is a Honda which will run right around 2000bux and the second is a KIPOR it will give similar performance to a comparable Honda and cost around 5-600bux less....
...any generator with a db rating over 70db will become very annoying pretty quick...I'm willing to bet, the one you mentioned will have a db rating in excess of 80(or even 90)db...very annoying pretty quickly out in the nice quiet woods!!!!!!!!
p.s. if they have the Honda I linked to for 999bux, jump all over it...the MSRP on the unit I linked to is around 2500bux!!!!!!!!!!!.......mj
NCOretiredEd wrote:Called them....OOOPS!!! that was for a Honda 2000.
TheBizMan wrote:I bought a Champion 2000 from Cabelas for $600. It is quiter then the Honda 2000. It runs my small AC with no problem.
bdosborn wrote:TheBizMan wrote:I bought a Champion 2000 from Cabelas for $600. It is quiter then the Honda 2000. It runs my small AC with no problem.
That must be the new Champion Inverter model because the synchronous type isn't quieter than a Honda, not by a long shot.
I haven't checked in a while but Mayberrys used to have the best price on a Honda 2000. $850 to your door.
Mayberrys
The Champion Inverter model is pretty popular over at the big RV forum.
110 pages of Champion Inverter Generator
I think Costco has been carrying them...
