small, light 12V deep cycle battery??
Postby CARS » Thu Apr 21, 2011 2:22 pm
Does anyone know of or use a real light, small deep cycle battery??
Chris'
Autobody
Restoration
Service
CARS
Postby aggie79 » Thu Apr 21, 2011 4:46 pm
Chris,
From several postings by "Arne" on the board, I am using one of those Group U1 scooter batteries. They are around 25 pounds and quite small.
Postby dguff » Thu Apr 21, 2011 5:29 pm
I have used one for years. I also use it to power my electric golf bag carrier. Sometimes they are called wheelchair batteries. It is about 7 3/4" long, 5 1/2" wide and 6 1/2" tall. It is a gel type deep cycle battery.
Jerome
Jerome
2008 Guffman
dguff
Images: 69
Postby CARS » Thu Apr 21, 2011 5:41 pm
Thanks guys!
I never even thought of that. Becky has a Rascal that we use at car shows and I knew it was a 24v system. What I forgot was that the battery's were 12v!
I even have a pair of old ones. I can mock up the battery tray this weekend!!! :thumbsup:
Chris'
Autobody
Restoration
Service
CARS
Postby prohandyman » Thu Apr 21, 2011 9:01 pm
Batteries Plus!
Dan
prohandyman
Images: 785
Postby Miriam C. » Thu Apr 21, 2011 9:48 pm
Some of the new marine stuff has very small batteries. There is a light weight trolling motor that has a 15 pound battery for it.. 8) Will do a trolling motor at full speed for 2 hours so should do lights for a while.
http://www.youtube.com/watch?v=VV3VRXWR ... ture=share
http://www.electricpaddle.com./
Batteries are really getting smaller and more efficient!
Postby 48Rob » Fri Apr 22, 2011 7:20 am
Alarm systems use a battery about half the physical size of the scooter batteries, they are 4 Amp hours.
I have one I use to power my amplified antenna for the camper.
Rob
<img src="http://www.homesecuritystore.com/images/Product/icon/BD412.jpg">
48Rob
Postby CARS » Fri Apr 22, 2011 9:50 am
Miriam C. wrote:Some of the new marine stuff has very small batteries. There is a light weight trolling motor that has a 15 pound battery for it.. 8) Will do a trolling motor at full speed for 2 hours so should do lights for a while.
That is neat, but OMG $$$$
http://www.electricpaddle.com./products.html
$335.00 for an additional battery??? :?
Chris'
Autobody
Restoration
Service
CARS
Postby wannabefree » Fri Apr 22, 2011 8:53 pm
If you are really serious about small and light, use Li-ion or Li-poly. A 30Ah pack runs about $500, and you will need a special charger. Your next best chemistry is Ni-MH. These too are very expensive, require a special charger, and don't last as long as Li-po.
Most of us who are weight conscious are content with 35Ah SLA batteries in the 25 pound range. Use LED lighting, forget running a micro or AC, run your fan as little as possible and it can last a week or more between charges.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Miriam C. » Fri Apr 22, 2011 11:29 pm
:? :shock: :lol: Oh my. I didn't look at that!
You can also run two 6 volt batteries in series and get 12 volt. Less weight and way less cost!
