48Rob wrote:Steve,
Sounds good!
Do you know what the dollar amount is that you have invested to get the 200 Watts of solar power?
Rob
I was very lucky, the solar panel was given to me by a mate that installs them on houses. The frame was damaged so they couldn't use them and they dont give them to employees as they tend to 'damage' a lot more then...
The regulator and LED display cost around $150AUD, you can get cheaper but I wanted the LED display and it needed to cope with an open circuit of 46V which only the MPPT ones do (they also run the panel at it's most efficient voltage and effectively boost the output into the battery)
Then there was cableing and plugs, probably cost me $200AUD all up but if I'd bought the 167W panel (I already owned a 30W panel) it would have cost around $1000AUD more.
Here's a pic as an example fo the size of the panel.
Also I'd say go for the 24V panel and MPPT controller, you can use thinner cables and the higher the voltage difference between battery and panel the more boost the MPPT controller can provide. At one point I saw under 2 AMP at the panel and over 5 AMP going into the battery. If I slide the panel off the roof and set it up properly I'd expect to see close to 10AMP going into the battery.
Cheers
