by proformance » Tue Apr 26, 2011 10:24 am
IMO......
It is not just an issue of having a hole to vent, you need to evacuate the gasses by having air circulate through the enclosure. I recommend placing two holes in your enclosure, an exit hole near the battery and an entrance hole on the opposing side. Add a computer fan to the inside of the entrance hole so the fan draws fresh air into the enclosure. Optimally, place the entrance hole opposite the battery and high up on the enclosure. Then place the exit hole in the floor opposite side of the battery from the fan so the corrosive gasses exit out the bottom of the enclosure/trailer. But, you can actually place both holes in the bottom, sides, front anywhere you feel are convenient and out of the way as long as they are somewhat across from one another to create a cross-ventilation. Just try to keep in mind that you are trying reduce and/or eliminate the concentration and possible exposure of yourself and other items to the corrosive gasses. Add a nice slotted cover over the outside of the holes to prevent rain from entering. Again, be sure to install the fan so that it draws fresh air in so that the corrosive gasses are not passing through the fan.
Proper control of the fan,
The fan only needs to operate when gassing occurs, which is when the battery is in excess of approx 13.6V., basically when the battery is under charging conditions. To accomplish this in a manner that allows the fan to operate seamlessly (no interaction from you) I recommend installing a batter isolator to control the fan operation in/or about the trailer battery enclosure.
Proper installation of a battery isolator to accomplish this task requires wiring your trailer battery POS to the Battery-A Terminal of the isolator, and the computer fan POS to the Battery-B Terminal of the isolator. Wire all POS charging sources (your tow vehicle and any other battery charging device you may use) to the Alternator Terminal of the isolator. All GND wires need to tie to a common location (Batt-Neg and/or chassis GND). Wiring in this manner will activate the fan only when power is applied to to the Alternator terminal of the battery isolator. Basically preventing your fan from running when not required, and discharging your trailer battery.
