by 48Rob » Tue May 10, 2011 6:28 pm
If you are trying to put a switch inline on a very heavy battery cable then no, a rocker switch is too light duty.
If you are using wire which is equally rated to the switch at 12 Volts, 10 Amps, then they will work.
A fuse between the battery and first shut off switch is a must, if you don't already have one, and should be rated at no more than 10 Amps.
Rob
