by tonyj » Wed May 18, 2011 1:04 pm
Many lights come with one wire because either the backing plate or mounting stud acts as the negative, or ground side of the circuit. This requires the light socket to either attach to the grounded trailer frame, or will require you to make some provision to run a ground wire to the backing plate or stud of the light socket. Trailers and many car circuits use this same wiring principal to reduce the number of wire runs. The trailer (or car chassis) acts as a big ground circuit, which is then attached to the negative (ground) battery lead.
This is why faulty ground circuits between the tow vehicle and trailer cause so many problems. Make sure you have a good ground lead from the tow vehicle either through the trailer wire connector, or a dedicated, detachable ground from the tow vehicle to the trailer. Many older wiring schemes depended on grounding through the trailer hitch itself--very unreliable. The white wire on on the trailer wire connector is the ground circuit. The short white lead on the trailer side of the connector should be attached to a reliable grounding spot on the trailer. Make sure and use an ohmmeter to check from the connector to the ground attachment point to make sure you have a good ground.
tony
