3-way light switch
3-way light switch
Postby 2ndmile » Wed May 18, 2011 2:06 pm
I have searched but could not find anything. Is it possible to wire a 3 way DC switch or is there such a thing. I would like to have one light that can be activated by a switch from either door.
Brian & Susy Morris
Wife's blog: Chiot's Run - Cultivating a Simple Life
Our Company: 2nd Mile Productions - Videography and Website Design
2ndmile
Postby bobhenry » Wed May 18, 2011 2:12 pm
Not needed it's just like the dome light in your car. Simply run 2 hot wires one from each switch and ground the light in one spot It will work swell!
Postby TBuilder » Wed May 18, 2011 2:49 pm
Are there any adverse effects if both switches are "on"?
TBuilder
Postby zipz71 » Wed May 18, 2011 3:06 pm
TBuilder wrote:Are there any adverse effects if both switches are "on"?
You would have to turn both switches off to turn the light off.
Correct wiring shown here.
http://tnttt.com/viewtopic.php?t=11307
or here
http://tnttt.com/viewtopic.php?p=366087
Jeff
zipz71
Postby 2ndmile » Wed May 18, 2011 7:17 pm
Excellent find Jeff. Just what I needed.
Brian & Susy Morris
2ndmile
Postby chorizon » Wed May 18, 2011 7:19 pm
brian_bp wrote:An ON-ON SPDT switch (the normal "three way") outside, plus an ON-OFF-ON SPDT switch inside (which could be used to defeat the outside switch as Larwyn mentioned) would be a nice setup.
Yeah, the the thread Zip mentioned helped me quite a bit. Pay attention to the quote above in that thread and you'll have the ability to "lock-out" one switch from another.
chorizon
Images: 94
Postby bobhenry » Thu May 19, 2011 6:28 am
Now you know why I put in his and hers lighting on the sidewalls.
Postby TPMcGinty » Thu May 19, 2011 6:47 am
Get a light with a switch located ON the light. The switch can be reached from either door of a tear. It will take less wiring, less switches, and less complication.
Tim
TPMcGinty
Images: 146
Postby Dale M. » Thu May 19, 2011 9:42 am
Bottom line is 3 way DC switch/lamp circuit wires exactly same way as 120V AC 3 way switch wires...
Dale
Dale M.
Images: 18
