dh wrote:In a 7 pin connector the center pin is reverse lights. Just wire them up to the center pin and ground like you would the Tail/Stop/Turn lights. A 5pin flat will also work for reverse lights, but the 7pin allows for electric brakes and charging the trailer battery while towing.
Yota Bill wrote:dh wrote:In a 7 pin connector the center pin is reverse lights. Just wire them up to the center pin and ground like you would the Tail/Stop/Turn lights. A 5pin flat will also work for reverse lights, but the 7pin allows for electric brakes and charging the trailer battery while towing.
That is not always the case. There are no specific standards that are followed when wiring a trailer, and many manufacturers, and especially home builders, do things completely different. You must test the connector and never assume anthing is wired the way you are used to.
slowcowboy wrote:
then with a 7 way plug you have a red wire going to your vehciles altenator or the positve post on your battery to recharge your teardrops battery.
on the teardrop the red wire goes to your teardrops positive post on the teardrops deep cyle battery.
Slowcowboy.
proformance wrote:Yota Bill wrote:dh wrote:In a 7 pin connector the center pin is reverse lights. Just wire them up to the center pin and ground like you would the Tail/Stop/Turn lights. A 5pin flat will also work for reverse lights, but the 7pin allows for electric brakes and charging the trailer battery while towing.
Not entirely true.
There is a SAE (Standards of Automotive Engineering) trailer connector format that is practiced throughout the Automotive Manufacturing Industry. But, you are correct that there a a lot of hack repair shops that pay no attention to this format and basically wire as they please. If you have an OEM harness/connector on your vehicle, it should follow the SAE format.
