TV Antenna
TV Antenna
Postby jerry101jlh » Fri May 27, 2011 2:19 pm
We have a 2011 Little Guy Silver Shadow and are considering installing a tv. I think that a side mount antenna best. Anybody have any ideas or antennas that fit this configuration to point me to? If this is addressed elsewhere on the forum I didn't see it, so apologize if it is. Thanks for any help and/or ideas.
jerry101jlh
Postby bobhenry » Fri May 27, 2011 2:32 pm
I put my red neck antenna on the side !
Postby bdosborn » Fri May 27, 2011 5:27 pm
I mounted my redneck antenna on a pole attached to the tongue box using quick grips:
Images: 806
Re: TV Antenna
Postby Mr Boo » Sat May 28, 2011 9:36 pm
jerry101jlh wrote:We have a 2011 Little Guy Silver Shadow and are considering installing a tv. I think that a side mount antenna best. Anybody have any ideas or antennas that fit this configuration to point me to? If this is addressed elsewhere on the forum I didn't see it, so apologize if it is. Thanks for any help and/or ideas.
Jerry, I found a mini HDTV antenna on Ebay, It works really well Model GE 24769 Outdoor Antenna for Digital HDTV Futura, I have updated my Album showing my install, It comes with everthing you will need, adjustable antenna mount, power amplifier that will need to be wired for best reception, I hard wired mine into the 12V house batteries so I didn't use the supplied 110V AC power supply as it generates 12V DC. I hooked this antenna up to my 23 Inch LCD, LED Flat screen in my work shop concrete walls filled with rebar steel roll up main door witch was closed, now I usually have very week car sterio reception in the shop but when I did a channel scan with my HDTV I was amaised having 11 crystal clear HD channels, Check out the reviews on this antenna. Good luck on your project. :thumbsup:
Mec Tech
Mr Boo
Images: 23
Postby LDK » Wed Jun 22, 2011 5:20 pm
I bought a couple of these Terk HDTVa antennas and they work really well and it has one of the best reviews. It's an amplified uhf/vhf indoor antenna. I'll eventually use one in my camper when I get done with it.
LDK
