My trailer has this battery in it. My question is how do I figure out the Amp Hour rating?
Part Number: BAT 8240
Product Line: NAPA Batteries - Regular
Attributes:
Battery Application : Marine
Battery BCI # : 24DCM
Battery CA @ 32 Degrees F : 685
Battery CCA @ 0 Degrees F : 550
Battery Height : 8 7/8"
Battery Length : 10 1/4"
Battery Load Test Amps : 275
Battery Posts Type : Top Mount
Battery Reserve Capacity : 140
Battery Weight : 45.4
Battery Width : 6 13/16"
Measuring State of Charge : Batteries below 12.4v (6.2v for 6 volt batteries) must be recharged before an accurate load test can be performed.
Physical Inspection : Terminal Inspection: Broken or loose due to abuse, burn marks from shorting, damage from fire, explosion or collision.
Safety Precautions : Batteries expel explosive gases. Keep sparks, flames, burning cigarettes or other ignition sources away at all times. Always wear safety goggles and face shield when working near batteries. Do not leave a battery on charge for more than 48 hours.
