GuitarPhotog wrote:If you use that 30A inlet, you will need a shore power cable with a 30A female connector on it.
Be advised 30A extension cords are heavy and expensive! If you don't really need 30A service in your trailer, you're better off using the 15A inlet pictured, a 15A extension cord, and the adapter shown in Madjack's post.
<Chas>
rebapuck wrote:Here's my question.
I currently use an extention cord, from the shore power, through an opening. I plug a 6-outlet power strip to it to run fan/heater and a lamp in my VW. I run a second cord, out through same opening, from the power strip to the ttt. This works for me.
I would like to have a small permanent installation, in the side of the bus, that has a 15amp "incoming" and a 15amp "outgoing" beside it.
Anyone seen something like that?
