I need some expert advise on the install of the breakers for the 110 AC side of an WF 8900 power converter
A) I'm not sure where the lines are supposed to go
B) Green to Ground - White to neutral - Black to Hot
C) on the converter itself there is a black wire available for branch circuit and a pin (black wire) pig tailed off of that for a branch breaker
So my question is how does the circuit it self going to get the benefit of the breaker? seems to me the shore power is just connected to the the breaker and circuit it self .
And does the hot of the shore power than go to the screw on the breaker as well as that black wire from the converter
Any help would be apreciated thanks
