I need advice on a solar purchase please
Postby JoshInReno » Tue Aug 02, 2011 6:50 pm
Hello everyone.
Sometime this month, I will be buying a solar panel for my trailer. I am leaning toward something in the 50w range, but more is always better. So I came across this today, and am wondering if it is a decent deal:
http://reno.craigslist.org/mat/2515387183.html
My questions are:
1. Are they link-able? In other words, can I tie two of them together to get a 95w panel?
2. The specs are very faded, but I THINK each panel is capable of 1.22 amps if I read the label right. Does this sound correct?
3. How many amp hours can I reasonably expect, per day, to get out of a system like this?
Any help would be greatly appreciated!
JoshInReno
Postby Breezy13 » Wed Aug 03, 2011 8:26 am
If you get 5 hours of bright sunlight a day, with two panels, you could possible get 10 -15 Amp hours/day.
Have you looked into charge controllers yet?
Breezy13
Images: 11
Postby bdosborn » Wed Aug 03, 2011 8:40 pm
It looks like they are 18 watt panels so the three of them would add up to around 54 watts. I can't tell what the peak voltage is but 16V in the sun without a load is a little on the low side. You might have a pretty low voltage on hot days. However, you could wire them in series with an MPPT controller and it wouldn't be an issue. But, an MPPT controller is $200.
A 45 watt solar panel on eBay is about $115 (with free shipping) or $2.55/watt.
The 54 watt craigslist panels are $135 or $2.50/watt.
I'd pass on the craigslist panels as I'd rather have a new, warranted panel with published performance parameters and being used, they aren't cheap enough to tempt me.
Images: 806
Postby JoshInReno » Wed Aug 03, 2011 9:23 pm
bdosborn wrote:It looks like they are 18 watt panels so the three of them would add up to around 54 watts. I can't tell what the peak voltage is but 16V in the sun without a load is a little on the low side. You might have a pretty low voltage on hot days. However, you could wire them in series with an MPPT controller and it wouldn't be an issue. But, an MPPT controller is $200.
Thanks Bruce. The panels WERE listed as 45 watts apiece. It looks like the seller has now changed the ad.
At $45 and 45 watts, I was interested. But not at 18 watts. Thanks for catching that for me.
JoshInReno
Postby bdosborn » Wed Aug 03, 2011 9:38 pm
Images: 806
