License plate light
License plate light
Postby Woodbutcher » Wed Aug 31, 2011 8:58 pm
I am hooking up a license plate light and there is only one black wire. I tapped into the running light wire but the light does not go on. It could be the bulb or the wrong wire hook up. Help me!!!!!!!
Woodbutcher
Postby emiller » Wed Aug 31, 2011 9:33 pm
Usually they are grounded when you attach to a metal bodied vehicle. You might have to run a ground wire to one of the screws.
emiller
Images: 157
Postby madjack » Wed Aug 31, 2011 11:57 pm
emiller wrote:Usually they are grounded when you attach to a metal bodied vehicle. You might have to run a ground wire to one of the screws.
...YUP........................................................ 8)
Postby starleen2 » Thu Sep 01, 2011 6:53 am
^^ What they said ^^ :thumbsup:
starleen2
5th Teardrop Club
Postby Woodbutcher » Thu Sep 01, 2011 7:09 am
Thanks guys. That's what I'll do. I want it to work before I close up the underside of the hatch.
Woodbutcher
Postby bobhenry » Thu Sep 01, 2011 7:46 am
All DC powered items need a path in and a path back to the ground side of the battery. There are many many items that require that a ground be added to complete the path as they are usually designed to ground thru the frame. You will find a single HOT wire on many types of clearance lights, so just add a ground wire with an eyelet on the end and place it around the mounting screw hole and attach.
Postby Woodbutcher » Thu Sep 01, 2011 11:34 am
Thanks guys, that was it. Just added a wire and connected it to the ground I already had in the hatch. Took 2 minutes.
This is why I love this board. In a few moments someone is there with the answer! :applause:
Woodbutcher
Postby angib » Sat Sep 03, 2011 7:46 am
And if you can, run the ground wire inside the light and fix it to the light's base plate there - ground wires connected externally to exposed mounting screws always seem to fail eventually, due to corrosion.
angib
5000 Club
5000 Club
Images: 231
