jmedclay wrote:Thanks Engineer Guy (we are brothers). I suspect that it's not a problem given the particulars of what I've done and list anecdotal evidence. Snipped. I'll post what I find later for thems that might be interested.
I do like your sig. Physics doesn't care a whit.
Some handy links, Ancor wire tech info, a relevant NEC paragraph and NEC tables, respectively.
http://www.marinco.com/page/allowable-amperage
http://www.inspectionnews.net/home_insp ... ation.html
http://www.houwire.com/products/technic ... le310.html
Correcting and adding to previous info:
I'm using Ancor 105C wire, not 90C
12g for the 20A, 120V AC circuits.
14g for the DC circuits that are fused at 10A or less.
My wiring/fusing is fine after derating for encapsulation, but I read enough to know that one could easily make a quality electrical system that was code compliant until adjusting for the effects of insulation and ambient temp. I also read enough to see that the temperature rise of thermally insulated conductors can be substantial, particularly in areas of high ambient temperature or solar gain and long duration, heavy use. Short duration use of higher current devices like hot plates/toaster ovens helps prevent unwanted outcomes, but thats a little too random for my taste.
It's time to finish the insulation installation. I am eager to get the front/roof skin installed.
Latest pics, not yet in my gallery, here:
http://www.flickr.com/photos/21624415@N ... 017251243/
