Power req's of computer speakers
Postby Treeview » Mon Mar 05, 2012 3:03 pm
The indash stereo in my ToyBox is awful. Having tunes is important, second to AC/heat in the accessory column.
I've got some speakers from a home sound system and extras from computers too. Can either of these be driven with the power of the stereo output? The space in the cab is limited so using the smaller speakers in their own cabinets would be easier to use than regular car stereo speakers. There is an inverter mounted in the cab if I do need to use external power.
When I look for a new in-cab stereo I'll find one with a remote. Then I can run wires from the cab to the Box and only have one stereo. My laptop and phone are along too. They'll be connected into the system too.
Treeview
Images: 30
Re: Power req's of computer speakers
Postby pmowers » Mon Mar 05, 2012 10:47 pm
Check the back of your computer speakers, most of them run on about 6VDC, through a barrel jack, you can check the wall wart that probably came with them. I would just use one of those multi-volt 12VDC adapters. I have a couple of sets that used 4 "C" cells and would run for what seemed forever on one set. The same thing may apply to the home stereo speakers, although a lot of them depend on the power driving from the amp.
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby Dale M. » Tue Mar 06, 2012 10:03 am
I have a set of YAMAHA speakers (amplified) that run on 14 V DC so the would probably run just fine on 12 volts (actual about 13.5 volts)...
Dale
Dale M.
Images: 18
Postby kludge » Fri Mar 09, 2012 8:58 am
Would this work?
It will work on 12V-14V just fine and there's an Aux jack in the back for connection from whatever. The base can be screwed off and mounted on a hand made bracket. It has PLENTY of sound for small spaces. Has a remote control too.
http://www.klipsch.com/igroove-sxt-ipod-speaker-system
kludge
Postby Treeview » Fri Mar 09, 2012 10:11 am
Yes...along the lines of what I want.
Earlier this week there was an in-dash unit like that at a deal a day site. It was an AM/FM/CD player with a flipout shelf for a phone dock. Remote too...while I took a few minutes to research the unit the deal sold out....dang!!!
It'll come up again...I hope!
Treeview
Images: 30
Postby zipz71 » Fri Mar 09, 2012 5:41 pm
kludge wrote:Would this work?
It may not run on 12v. The older one had an external power supply which supplied both negative and positive voltages. IIRC it had a 4 pin power connector. I don't know if the new one has the same power supply.
Jeff
zipz71
Postby kludge » Mon Mar 12, 2012 12:27 pm
zipz71 wrote:It may not run on 12v. The older one had an external power supply which supplied both negative and positive voltages. IIRC it had a 4 pin power connector. I don't know if the new one has the same power supply.
The iGroove SXT will run on 12V, I promise. The original, like you said, won't.
kludge
