Smoke Test
Smoke Test
Postby Shadow Catcher » Wed Mar 14, 2012 8:14 pm
Well I performed the smoke test on the inverter install and the Vectron battery monitor, none escaped. The inverter uses a 30A DPDT switch and feeds the 120 AC circuit beakers from either shore power or the inverter.
The Vectron needed only to have the amp hour of the battery input and it works very well. I particularly like the % depth of discharge measurement.
Re: Smoke Test
Postby Forrest747 » Fri Mar 16, 2012 8:37 am
86823
Just in case you needed to put some back in.
Forrest747
Cowbell Donating Member
Images: 447
Re: Smoke Test
Postby angib » Fri Mar 16, 2012 10:45 am
No, no, no! That's cheap imitation smoke made from burnt tomato soup and old Warhol posters. That's no good for anything.
You need gen-you-whine replacement wiring harness smoke, like the manufacturer fitted in the first place:
angib
5000 Club
5000 Club
Images: 231
Re: Smoke Test
Postby Forrest747 » Fri Mar 16, 2012 10:48 am
I will have to disagree strongly. Getting that stuff through customs is a bear. If your going foreign than get the premmier jamican electrical smoke.
Forrest747
Images: 447
Re: Smoke Test
Postby tonyj » Fri Mar 16, 2012 11:03 am
Well, whatever brand you buy, avoid the dehydrated smoke. It never works. Unless I am using the wrong type of water . . . :thinking:
tony
tonyj
Images: 160
Re: Smoke Test
Postby eamarquardt » Fri Mar 16, 2012 11:10 am
Lucas, by far, makes the best electrical smoke. It's only shortcoming is that it doesn't leak oil.
http://www.triumphspitfire.com/Jokes.html
Gus
eamarquardt
Images: 150
Re: Smoke Test
Postby GuitarPhotog » Fri Mar 16, 2012 11:15 am
I may be deficient, but in all my years of letting the smoke out of electrical parts, I've never been able to put it back.
Maybe my equipment has been lacking a "smoke replacement port?" I've been blowin' smoke at it for years with no good results.
:beer:
<Chas>
GuitarPhotog
Images: 55
Re: Smoke Test
Postby angib » Fri Mar 16, 2012 11:24 am
As you would expect Lucas makes the best kit for putting back smoke that's somehow leaked out ('practice makes perfect', you know...) and here is a photo of the full kit with filter (for smoother smoke...) and pressurisation valve:
And I think, forest747, your Jamaican smoke isn't necessarily fixing any problems - it's juss makin' ya faar more chilled out, mon......
angib
5000 Club
5000 Club
Images: 231
Re: Smoke Test
Postby Forrest747 » Fri Mar 16, 2012 12:07 pm
It comes with a box of Betty crocker brownie mix with each order. Which is perfect to chill with after trying to find the smoke ports
Forrest747
Images: 447
Re: Smoke Test
Postby bdosborn » Fri Mar 16, 2012 7:24 pm
Shadow Catcher wrote:Well I performed the smoke test on the inverter install and the Vectron battery monitor, none escaped. The inverter uses a 30A DPDT switch and feeds the 120 AC circuit beakers from either shore power or the inverter.
Got any pictures? I'm thinking of replacing my automatic transfer switch with a DPDT switch as the overhead to the solenoid is 1/2A.
Images: 806
