HELP!!
HELP!!
Postby jpmo66 » Thu Mar 15, 2012 2:08 pm
I am finished with my tear, except for one thing ... the trailer lights... I have the harness that came with my HF Trailer... I started this in the fall, and had all kinds of gremlins, the directional on one side would work, but not when i pressed the brakes...the top bulb was on one side and the bottom on the other, etc... I gave up as the weather and time ran out... I read all kinds of posts about this and decided my problem is the ground... I hooked everything up made better ground connections, and now the running lights work... but no brake or directionals at all...
Now, I am afraid it has something to do with my configuration. I am using tail lights from RW Johnson... therefore i added rear side running lights, I also added a light for the tag. Could this have anything to do with it? Does anyone have any ideas? It is making me crazy!
jpmo66
Images: 49
Re: HELP!!
Postby absolutsnwbrdr » Thu Mar 15, 2012 3:12 pm
Many people have had grounding issues with the bolt-together trailers, myself included. Did you run a ground wire from the harness around the trailer to each of the light fixtures? If not, I'd start with that.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: HELP!!
Postby jpmo66 » Sat Mar 17, 2012 7:06 pm
THANKS! ... Worked perfectly! All ready to get the inspetion and hit the road!
jpmo66
Images: 49
