I'm piling high lotsa scrap from my garage bay cleanup (gotta make room for the TTT) onto my car trailer. Old appliances, bed frames, wheels, rotors, drums, brake shoes and pads, shocks, brackets, pulleys, braces, steel, aluminum, brass, tin, riding mowers, push mowers, carburetors,electric motors, ecetera etcetera.... I am hanging on to three Chevy rear axles, two extra gearsets,a 327, and a 350, and a '73 C-10 front suspension w/discs that I never got around to using, and some usable carburetors and distributors that all may end up on Craigslist (as well as the non-running Fiero that blocked all this in for 12 years or more). It's amazing how much stuff can be piled into a 24' x 10' bay. I've got stuff packed in front and sides of my wife's Cobalt, and all around my Chevelle racecar (only fire it up once a year to scare the new neighbors now, no racing for four years).The inconsequential very small box of Romex I can keep for some other project (stationary, house or shed!).Sell it on Craigslist and use the money to buy what you need.
ebutler wrote:Romex is solid wire and is prone to breakage in installations where vibration is present. Stranded wire of the same size and weight will carry more current (due to skin effect)
....So a private individual can wire a RV with whatever will work, but if it is sold commercially (or even re-sold privately ??), then the wiring must meet code? If I ever finish mine, I'll probably never sell it anyhow, but good to know anyway. And I guess I should not rewire the wife's Puma with extension cords either.FWIW, the NEC prohibits the use of portable cord in an RV but allows romex (type NM). I used an extension cord in the teardrop anyways as I had an extra one laying around.
