bargman power
bargman power
Postby del » Thu Apr 19, 2012 9:10 pm
What I have found out;
This receptacle is off an early airstream, I think.
30 amp
Brand;Theo Bargman
part #60-0-3
The connector is not common (if only I had known before purchasing)
What I need;
The female connector that goes on the end of my 30a cord, and plugs into it.
any clues were to look.
I have googled bargman 60-0-3
and searched ebay for airstream power.
Pic i found on the net, a cleaner version of mine
thank you for any help
del
del
5000 Club
5000 Club
Images: 410
Re: bargman power
Postby Martiangod » Thu Apr 19, 2012 10:12 pm
Bargman 60-Q-3P rated at 35 amp from the 50's
Obsolete, most have been changed out to marinco's
I wouldn't use it
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Re: bargman power
Postby del » Sun Apr 22, 2012 9:43 am
Martiangod wrote:Bargman 60-Q-3P rated at 35 amp from the 50's
I wouldn't use it
Is the reason for not using, because it is old and obsolete, or something else?
del
del
5000 Club
5000 Club
Images: 410
Re: bargman power
Postby Martiangod » Sun Apr 22, 2012 9:07 pm
They are just a straight push, not a twist lock
They didn't stay engaged well when they were new, when worn problematic for staying plugged in
" IF "you find a good condition one, most likley will pay dearly for it
I would have changed out the recepticle you have just due to the amount of rust on the wire screws and spades.
Poor connections tend to heat up, seen many plugs melted right down from being in that condition
Chris
Martiangod
Images: 432
