I used an AGM for that reason but if you want to used a conventional deep cycle battery you need a vented battery box/compartment. Remember hydrogen is lighter than air. One example http://www.adventurerv.net/vented-batte ... -4085.html
terryjones1 wrote:None, if you used an AGM battery.
All AGM battery manufacturers recommend venting AGM batteries as they can vent hydrogen under certain circumstance. Do a Google search on VRLA thermal runaway to learn more.
2009 6.5'X11' TTT - Boxcar All it takes is a speck of faith and a few kilowatts of sweat and grace. Boxcar Build aVANger Build
