Dale, I understand what your saying about corrosion and really I hadn't thought about it. I do use dialectical grease on all my battery connections. My current battery that has been on the front of the trailer since last year was still spotless. Three connections didn't seem like much to me because I already have two per terminal with my current setup. I would Never let my terminals get anywhere near that funky before cleaning them. These are standard wet deep cycle batteries so a couple times a year I will have to remove the holding straps check the water level and check the cells with a hydrometer. Giving the connections a little TLC at the same time is really not a problem. I was more concerned with how to connect everything from the point of view of keeping the cells charged evenly as I can and having the setup optimized best I can as far as price, amount of wire, ect, ect. Now if these batteries were AGM batteries and they were tucked away in cubby in boxes having pull them out to clean the connections would be a Pita. The cargo hatch is very easy to access though. And I even made the hold downs so removing one wing nut allows you to check the water or remove the battery.
eamarquardt, Seems like I have also read that somewhere, But in my case I don't think it will be a problem. The trailer is parked at my house and stays plugged in 99.9% of the time. I do have a 3 stage WFCO power converter now that keeps the battery charged. Now once the solar is on there I plan on letting it maintain the batteries while parked at the house. If I park the trailer inside my shop then I will plug it in. This was some of the reason why I wanted to add the solar. I figured if it was going to be sitting outside in the sun might as well use that to maintain the batteries. I have a feeling the 160 watts of solar will not be enough to keep up with all our usage while dry camping. It should be plenty to maintain the batteries while not in use. Besides once I add two more 80 watt panels or 100 watt panels I know I'll have plenty.
All my stuff is here now so I plan on tomorrow after work setting everything in place and taking a look at what lay out works best in the space I have. Looking forward to getting it all connected and testing it out. Should make our up coming camping trip a little nicer! I did some testing the other afternoon and my TV pulls 27 watts AC and the bluray pulls 8 watts. I was pretty happy with that since one of the main reasons I wanted the inverter was to be able to run those two things at night when our 4 year old is winding down for bed. We tend to be outside at the campfire while he is laying in the bed watching a movie before bed. Besides that we only have a couple of very small things I plan on using it for. Walkie talkie charging base, digital camera charger, ect. Stuff I really don't want to go out and buy 12v chargers for each thing. It would have been nice to have an inverter large enough to run the microwave for a couple mins here and there with out needing the generator. But since its running wattage is 950 watts AC
It just wasn't practical to try and run it off an inverter. It would zap a lot of juice and the size inverter I would have to step up to just for that one item simply wasn't worth it.
