European AC Inlet?
European AC Inlet?
Postby kludge » Thu May 31, 2012 12:07 pm
Anyone know were I can get a European AC inlet? (besides Europe? :) )
Like this but allows you to connect a Euro style cord.
kludge
Re: European AC Inlet?
Postby Forrest747 » Thu May 31, 2012 12:35 pm
http://www.wellshin.com.tw/03_products/ ... socket.pdf
Not sure if this helps any. starts around page 5.22
Forrest747
Cowbell Donating Member
Images: 447
Postby H.A. » Thu May 31, 2012 7:53 pm
H.A.
Postby kludge » Fri Jun 01, 2012 1:02 pm
Not a troll question. Yes, I'm looking for the CEE 7/4 or 7/7 hybrid "Shuko" style inlet. Were building a new test shed at work. I can find the US types all day long, but my Google-Fu has run out trying to find the European one.
Your links look like they will work. I'll check Mouser and Allied.
Here's the plug and socket pictures from "wikipedia". Our typical European products are built with the 2 pin "europlug" but I need to be able to use the 7/4 or 7/7 Hybrid with earth connection as well for the test shed, since occasionally we use that style plug also.
I guess my question now is which one of these two below do I need? I plan on using an off-the-shelf "extension cord" to make the connections. Or will either one work?
http://www.internationalconfig.com/icc6.asp?item=70195
http://www.internationalconfig.com/icc6.asp?item=70198
I will probably make my own "extension cord" since I will want a custom length using these:
http://www.internationalconfig.com/icc6.asp?item=70141
http://www.internationalconfig.com/icc6 ... em=70161-A
Looks like I want to use the first one? (70195?)
kludge
Postby Forrest747 » Fri Jun 01, 2012 1:16 pm
Forrest747
Images: 447
Postby kludge » Fri Jun 01, 2012 1:26 pm
That's an innie. I need an outie.
H.A. had a link in his post.
kludge
