I will be powering 1 very small(smallest unit I can find)AC unit....1 battery Charger(unless I go with inverter) two outlet boxes in galley for electric skillet etc and two outlet boxes in camper for laptop cellphones and small heater in cold weather...
1. Should I use a Distribution Panel like Progressive Dynamics that host 120/12 volt and charges the battery or go with separate boxes for both and use a good battery tender/charger..the cost of a good Progressive Dynamics is just a little more or real close to the cost of a good battery tender, small breaker box and breakers....I already have a really good 12 volt panel installed in camper... my reasoning is if something goes bad its an easy task to run down the problem and replace it with the items being separate...but if an inverter/panel goes then its pulled out for repairs....what do you guys recommend?
2. Should I go 15 or 30 amp? I like 15 because the cord is smaller and easier to deal with..the cost of the items like the inlet and cord is cheaper....my Honda EU2000i and EU2000i Companion generators have a 30 amp twist lock plug already on them for times I would be without shore power so I could use 15 or 30(I would only need one and not have to Parallel them like I do on my Airsteam) but if I did go 30 amp I would probably use something like this
http://www.amazon.com/Furrion-FCKIT30-P ... +amp+Inlet
to get power into camper.....then into the panel or inverter..
so that's about it.....here is a picture of my camper if you have not yet seen one and all electrical items will come in on left side and be installed in lower left corner...any insight you can share to help me decide which routes to take will be appreciated...
