by 48Rob » Thu Apr 04, 2013 7:17 am
Most opt for the television with built in DVD, much simpler!
Size? I like an 80 inch screen, but it might be a b=it much for the kids eyes being that close?
For a more normal size screen, depends on where they will be sitting.
A flat wall mount is more secure than an adjustable swing away, but doesn't allow the screen to be tipped in case they are off to the side.
If you run 12/2 with ground, you can run a 20 Amp circuit and be fine with the TV, coffee maker, and a few lights, etc.
Have a pro verify after reviewing your complete plans and install the system for your childrens safety.
Add up the Watt total of all your draws and you'll have an idea how big a generator is needed.
Rob
48Rob on Thu Apr 04, 2013 1:02 pm, edited 1 time in total.
