Outside connector for 12v comming from battery
Postby qwerty11 » Mon Jun 17, 2013 1:28 pm
I need a 12v connector/receptacle to get power in from the battery. I know I could just run the wires directly and silicone everything up, but for my application, I need to be able to plug directly into the side of the trailer. Something similar to this would be great: http://www.amazon.com/Marinco-150BBI-On ... =12v+inlet
I know Marinco makes a 12v connector, but it is the cigarette type. Highest wattage cigarette plug I can find is 15A which isn't enough.
qwerty11
Re: Outside connector for 12v comming from battery
Postby RandyG » Mon Jun 17, 2013 2:22 pm
Check out parts-express.com, they have lots of connecters.
Randy
RandyG
Images: 115
Postby Shadow Catcher » Mon Jun 17, 2013 10:14 pm
Postby pmowers » Tue Jun 18, 2013 9:06 pm
Because of the thin walls on my CT conversion, I did a setup using standard 1/4" phone plug and jack. http://www.tnttt.com/viewtopic.php?f=42&t=51193&start=15#p950448 and use a weatherproof outlet cover 95725.
The 12 VDC is coming off of the converter inside my trailer. I have easily operated a portable electric cooler off of the outlet, as well as a number of other 12 VDC items. The system has been in place about a year now, and seems to be holding up well. A plus is that there are several accessories for RVs that work off of the same kind of plug such as fans, extension lights, etc.
Additionally, if you have modified your cord ends, it cuts down on people borrowing your stuff :twisted:
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby Bogo » Wed Jun 19, 2013 5:31 pm
If it is only for up to 30 Amps, then use a standard RV-7 trailer wiring connector. It'll likely be your low cost option, and replacements are available everywhere. Just hookup the Aux/Battery charge pin to the positive on the battery, place a fuse at the battery. Hook the battery ground to the ground pin on the connector. If you need more current than 30 Amps, look for flange mount Anderson Powerpole connectors, and get a standard RV electrical entrance door to cover it against the elements.
http://www.newhamstore.com/powerpole-he ... at_63.html
Bogo
Images: 39
