asianflava wrote:Sounds like you're wiring in series. You basically need to wire both leads from the lights to both terminals. Not a fan of wire nuts in mobile applications, but even less of a fan of quick splice (aka scotch locks, wire taps). Use the wire nuts, it's the lesser of the 2 evils.
qwerty11 wrote:Is the best way to do it is have a wire nut and one wire going off to first light and second wire going to second light or use a quick splice connector? Open to any other suggestions as well.
GerryS wrote:Solder is acidic, so it can actually shorten the life of a terminal. In aircraft. All those connectors are crimped... And that world friends, safety is paramount!
