Negatives all connect to the Battery Negative terminal. What I did was to put a terminal strip with all the terminals wired together (with bare copper wire jumpers) and then run one 10ga wire from the ground buss (terminal strip) to the Battery Negative terminal.
You could also just run directly from the ground buss to the negative terminal of the battery (in addition to the wire from the PD4045 to the batt. neg. terminal.).
I used four 12 VDC circuits, Lights, Fans, Accessory Outlets, and USB charger. Each is on a separate circuit each with a 10 A fuse. The unused wires, I just bundled up and tied out of the way. I might want to use them someday.
<Chas>
