by working on it » Sat Oct 05, 2013 9:31 pm
MtnDon wrote:Interesting but very expensive..
http://www.simpleray.com/Lithionics-Batteries-s/182.htmPlus I believe you need special charging equipment. Maybe someday as I am sure the prices will continue to drop. Now as long as they can stop those aircraft from catching fire (traced to Li-ion batteries.... and that Tesla car that was a total,loss due to a Li-ion battery fire....
I saw how expensive the batteries were, so I didn't give it a hard look...then you had to mention the
FIRES! Now I have to carry an extinguisher next to my smartphone.
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
