The blue and white are DC circuits and they go to fan, lights, and/or accessory outlets. First you need to "ring out" the blue and white wires to see where they go. Then you need to figure out how you want to allocate the DC circuits on your WFCO converter (the black box with wires hanging out). Google WFCO Converter and you'll find info about them, including reliability info.
You will need to purchase and mount a 12 VDC deep cycle battery. The size (and cost) depends on your energy budget. How many lamps, fans, accessory outlets you want to power from 12 VDC.
The jacketed red, white, and green (or bare) wire is for the 120 VAC. You need to ring them out to see what they were intended to hook up to. Maybe some lights and some outlets. The WFCO has spots for circuit breakers to manage the AC distribution.
You should find and download the wiring diagram for the WFCO. You can probably find it here on TnTTT or via Google on the web.]
You'll get lots of advice here, but if you know absolutely nothing about electricity you need a pro at least for the 120 VAC stuff. You can't kill yourself with 12 VDC, but you can start one hell of a fire! Ask me how I know!
<Chas>
