3 way DC switch
3 way DC switch
Postby Pauldb51 » Sat Jun 28, 2014 1:04 am
folks I am looking for some DC 3 way switches. I want to be able to switch on the porch lights (both sides) from either side of the camper and the same with the dome light, can any one out there point me in the right direction. I thought about using a house hold 3 way switch but they are too deep and I'm sure some of those RV's out there have a similar system but can't seem to find what i'm looking for HELP
Pauldb51
Re: 3 way DC switch
Postby eamarquardt » Sat Jun 28, 2014 2:10 am
Any single pole double throw switch will work. I did a quick search and found this switch:
http://www.wiringproducts.com/toggle-sw ... ff-on.html
It has a center off position which you may find handy (or not). It's also rated for DC (AC switches aren't as robust as DC switches) but if yer just running a small light I doubt an AC switch would give you any trouble.
I suspect the big box stores should have em in stock.
Hope this helps.
Gus
eamarquardt
Images: 150
Re: 3 way DC switch
Postby Dale M. » Sat Jun 28, 2014 10:42 am
Single pole double throw "on-on" which I believe is what you want...
http://www.delcity.net/store/Heavy!duty ... 789013.t_1
Or if you are into "Rocker switches...
http://www.delcity.net/store/Non!illumi ... 788835.t_1
http://www.delcity.net/store/Flat-Termi ... 788721.t_1
Might want to rummage around here also....
http://www.waytekwire.com/products/1406/Switches/
Dale
Dale M.
Images: 18
