cdc3jj wrote:I'm getting ready to start rewiring my 10' traveleze. Do I need to run the wiring through the gray plastic conduit? I'm going to be running a mini fridge, hot plate, toaster oven, possibly a roof a/c and small stuff like lights and phone chargers. I'm planning a dedicated outlet for the stove and the fridge, 2 accessory outlets for the cook area and 2 accessory outlets for phone/computer chargers etc. Also what gauge wire is advisable? I'm not planning on trying to run anything big off a battery. Perhaps just lights if we happen to be without an electric hook up. The camper originally had a small single fuse. Should I build in a small fuse panel? I apologize if some of this info has been covered before. I'm hoping to start running wires tonight. Thanks
citylights wrote:cdc3jj wrote:
I would recommend one of these, or maybe it's smaller brother if you don't need that many circuits.
http://www.amazon.com/Blue-Sea-Systems-5029-Block/dp/B000MMH1GC/ref=sr_1_4?s=hi&ie=UTF8&qid=1404335790&sr=1-4&keywords=blue+sea+fuse+block
MtnDon wrote:That is a satisfactory panel for low voltage DC but not for 120 VAC. I mention that just to make certain the recommendation was for DC and not AC. (see last line of the specs on the page linked to; 32 VDC maximum)
Users browsing this forum: Google [Bot] and 3 guests
