kayakdlk wrote:You can get SPDT 12 v switches almost anywhere. Radio shack, auto zone, ebay, amazon, etc.. They are rocker type, flat, toggle with handle, round whatever type you like. You may have to run a smaller wire to them and clearance in the wall may require shims but all easy to do.
Dan
kayakdlk wrote:A SPST - Single Pole Single Throw has two post and usually labeled on/off. While a SPDT = Single Pole Double Throw. It has 3 posts on it and would not be labeled on/off since if wired as a 3 way switch off could be off either way depending on which of the two switches you used to turn the light off. Google SPDT and click on more pictures for different types switches.
captainkynan pointed you to a wiring diagram
here are some more examples:
http://www.tnttt.com/viewtopic.php?t=19864&p=269634
http://www.tnttt.com/viewtopic.php?f=30&t=60249
Dan
