Porch Light Switch - Using 125V AC switch on a 12V DC ciruit
Postby Tommy2tone_1999 » Sun Aug 31, 2014 9:22 am
The LED porch lights I'm mounting have external switches. I was wisely advised to patch an internal switch into the ciruit so I could see what goes bump in the night in safety. I purchased 2 16A 125V AC rocker switches like the one shone here. Is is safe to use these switches on a 12V DC circuit that is fused for 20A ? I think I know the answer to this, but maybe my assumption is incorrect.
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Re: Porch Light Switch - Using 125V AC switch on a 12V DC ci
Postby Greg M » Sun Aug 31, 2014 11:40 am
With the very low current of the led lights, you'll have no trouble. It's when you get into higher current loads that you can have problems.
Greg M
*Geek Extraordinaire
Images: 85
Postby Kharn » Tue Sep 02, 2014 12:16 pm
20 amps of LED lighting would probably be enough to guide the Space Shuttle down from orbit. 8)
Your current draw is likely in the range of .25-1 amps per light, so the rockers are more than fine.
Kharn
