Over or under?
Over or under?
Postby kenafp » Tue Sep 23, 2014 11:41 am
In designing the electrical systems, what lines do you install under the trailer, and what systems do you install inside the roof?
It's a good life!
Ken
Build Journal: viewtopic.php?f=50&t=60665
kenafp
Re: Over or under?
Postby bobhenry » Tue Sep 23, 2014 1:30 pm
Generally the towing lights run under the trailer...............
However !
I have trailers where the lights are built into the body so even the towing lights are routed thru the body.
I don't think there is a hard fast answer to this question but there is one thing to remember if they are in the body they are probably far safer and have less chance of damage.
The lights down on the frame are harder for a fellow motorist following you too close to begin to see. I like moving the light upward on the body.
Re: Over or under?
Postby Ron Dickey » Wed Sep 24, 2014 1:06 am
in my old trailer I put the wires inside then later had to cut them all and start over. If you put them in the body you must be able to get at them. These are the wires the run the lights that get you safely down the road.
On my new trailer I am putting conduit on the under side with connections where with a simple screw driver I can get at them. and if I need to replace any I can run a electric wire tape and run a new one. and if I am on the road I can run the wire on the outside leave the cover uncovered and attach the wire and then fix it later at home. I am doing that because in some california mountains there is a little animal that likes to eat wires. He is really looking for the brake fluid lines on the cars because he loves the taste of brake fluid. But for the most part and if you look under most trailers you will see the wires tied to the frame.
You should also carry a electric repair kit.
caps, electric tape, small volt Meter(digital ones light up in dark) if you know how to use one, extra wire, something to splice the wire with (a sharp blade will do), zip ties or wire, Red Lens tape for broken lens, flash light one for head works best you hands will not be free and holding one in your teeth is not fun, and of coarse spare bulbs unless they are LED's (then you might want an extra)
How ever my marker lights do have the wires in the walls (I have it set up so I can get in the walls if I need.
Ron
173882......173887
Ron Dickey
Images: 787
Re: Over or under?
Postby Tommy2tone_1999 » Tue Oct 14, 2014 11:51 am
On mine, trailer lights and Battery leads run under, and wires to outlets, cabin and galley lights and the radio go above or in cabinets
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
