Unexplaind light
Unexplaind light
Postby Shadow Catcher » Sat Oct 04, 2014 6:57 pm
Nancy calls me out to the tear the other morning as one of the tail light is on, and it is sitting there not connected to anything. Turned out to be moisture (it has been raining) had gotten into the seven prong plug and was shorting out. The holder for the plug puts the wire end up. A little contact cleaner and a plastic bag (to keep more rain out) until I can seal the end.
Re: Unexplaind light
Postby Redneck Teepee » Sat Oct 04, 2014 9:14 pm
Love those "Electrical Gremlins"...sounds like you found it quickly though. I had a tilt bed car hauler once that started blowing tail and side marker fuses, I tilted the bed up to visually trace the wires, came up empty, replaced the fuse worked again, put the bed down and blew it again. I now knew what was happening but still took a keen eye and mirror to find the pinch point, pulled out the factory wire section and rerouted new wires clear of the pinch point thru a conduit I welded on and problem disappeared....frustrating as hell.
:x :x :x
Redneck Teepee
Images: 21
Postby Shadow Catcher » Sat Oct 04, 2014 9:37 pm
Actually I had an idea because last winter the snow got deep enough to fill the plug and the same thing happened.
Postby working on it » Sat Oct 04, 2014 10:52 pm
Redneck Teepee wrote:Love those "Electrical Gremlins"...
gremlin (WB).png (98.67 KiB) Viewed 1403 times
173193172890148599
working on it
Images: 457
Postby Kharn » Sun Oct 05, 2014 6:29 am
You might want to put a disconnect on your battery.
Kharn
