Best a/c un its, best for the money?
Postby gene so » Thu Dec 11, 2014 6:32 pm
Hello,
In the design stage of my teardrop, I have purchased a near new pop-up camper that a low lying tree branch removed the top two feet. I intend on using all the fixtures and items in my teardrop. There is no A/C unit and I figure I can splurge and obtain one. My trailer will end up being nine feet long and well insulated since I was raised in Minnesota.
What a/c unit and how large would you recommend for me? Other campers have told me about the noise factors with some of these units. Whats the best A/C for the money?
Thanks for your attention in this matter.
Gene So
gene so
Re: Best a/c un its, best for the money?
Postby 48Rob » Thu Dec 11, 2014 7:35 pm
The cheap 5000 BTU window units that sell for a hundred dollars or less work very well.
They/any unit, will work best when placed higher up, rather than down at floor level.
Any A/C can be noisy. If you spend a lot more, you might reduce it a bit...]
For the pure pleasure of being cooled off when it is miserably hot, a little noise is easy to ignore.
Rob
48Rob
Postby lrrowe » Thu Dec 11, 2014 9:06 pm
48Rob wrote:The cheap 5000 BTU window units that sell for a hundred dollars or less work very well.
Rob
Agreed. I for one have no issues with the AC noise. Many times while in campgrounds, it does help to drown out unappreciated noise.
Bob
lrrowe
Images: 439
Postby Shadow Catcher » Thu Dec 11, 2014 9:48 pm
One solution that has worked well, This is virtually silent and works well even with the intake and down low.
80999
The write up is here http://www.tnttt.com/viewtopic.php?f=30&t=44561
