12v 7.2ah battery
12v 7.2ah battery
Postby hmikey » Fri Feb 20, 2015 11:14 am
I'm thinking of using a small 7.2 ah battery for a project. Not necessarily a TD project. When looking at these batteries I notice they require a different terminal connector than I'm used to. searched and couldn't get an answer. Possibly someone here might know. Appreciate any help. thanks Mike. PS: battery is 12v.
hmikey
Re: 12v 7.2ah battery
Postby bobhenry » Fri Feb 20, 2015 12:07 pm
If the battery has the square block like most small motorcycle batteries an eye connection and a bolt is all that is needed if they have a little tab then you will need the appropriate sized bayonette fitting that slides over the blade.
Postby hmikey » Fri Feb 20, 2015 12:33 pm
Thanks for a quick reply. I did figure out what I needed. The tabs are referred to as "F1" or" F2" depending on their dimensions-0.187 or 0.250. Never dealt with these small batteries before. Thank you. Mike
hmikey
Postby bobhenry » Fri Feb 20, 2015 12:52 pm
So yours has the little tabs on it ?
