another pd4045 question-dc negative
Postby Diemjoe » Thu Mar 05, 2015 12:38 am
I am starting to build my wiring diagram for the DC side of the electric. Looking at the pd 4045, the dc fuse block has the black wires (and two heavier gauge red). I am wondering how folks terminate the negative side. Do I need a termination block that consolidates the returns from the loads? That has a single run back to the battery?
Thanks.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
Re: another pd4045 question-dc negative
Postby GuitarPhotog » Thu Mar 05, 2015 12:44 am
Exactly
Make or buy a ground return bus terminal block that has multiple terminations in common. Use a wire suited to your total current draw to connect that bus to your battery negative.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Rocky5000100 » Thu Mar 05, 2015 3:38 pm
Thanks, this helps me too.
A single common ground for a few LED lights back to the ground block is correct right? The lights will be run in parallel.
Rocky5000100
Postby Diemjoe » Thu Mar 05, 2015 4:45 pm
Per the original question, I got this response back from the PD4045 customer service......
The Red wires are for 30 amp circuits and the blacks for 20 amp Max.
The terminals marked for the battery connections go to the battery only.
Hopefully this helps you too Rocky although not exactly answering your question.
Don Miller
Seattle
Trippinwithdon.com
Diemjoe
