This forum has been an absurd well of information. I am just starting a teardrop build and have learned almost everything from reading through this forum, the internet is a beautiful place. My main questions are about the electric system. I am very confident in simple electrical work, but only in 120V AC. I would love to share what I’ve come up with for my electric system and welcome any and all critiques and suggestions. I am going to try and be as exhaustive as possible.
First the crude electric drawing and then it will be explained:
The system breakdown:
1) Battery: I am actual still stuck on this. I am looking for an AGM, deep-cycle battery that is around 70Ah’s and can’t find any decent ones around. Any suggestions? Would this one work? http://www.batterysharks.com/SigmasTek-SPG12-90-IT-p/spg12-90it_gel12-90it.htm
2) Kill Switch - Between positive battery terminal and the PD4000
http://www.amazon.com/Battery-Kill-Safety-Disconnect-Switch/dp/B0017101BE/ref=sr_1_7?s=automotive&ie=UTF8&qid=1426947145&sr=1-7&keywords=battery+kill+switch
3) In-Line Fuse - I bought this:
http://www.homedepot.com/p/Unbranded-30-Amp-Glass-Tube-Fuse-Fuseholder-12-BP-HMK-RP/203298931?keyword=in-line+fuse
but unsure of how to install it, I’m thinking I might need something like this:
http://www.delcity.net/store/JCase-Inline-Fuse-Holders/p_800448
4) All wire from battery will be 8-Gauge, the positive wire then goes to the PD4000 from the Master Fuse and the Negative goes straight to the PD4000
5) RV Inlet Plug - 30 Amp 120V - Wired to the PD-4000 with 10-2 Wire
6) All of this will be powered by a Progressive Dynamics (PD4000) converter/inverter all in one sweet little machine
7) I will have 2 120V circuits. One will be 2 receptacles in the cabin and one will be 2 receptacles in the Galley.
These will be run with 12-2 wire and the first receptacle will be GFCI in each circuit.
Circuit 1: Cabin Dome Lights that will be through this Rocker Switch.
Circuit 2 - Cabin 12V Receptacles
Circuit 3 - Fantastic Vent Fan
Circuit 4 - Cabin Reading Lights with built in Switch
Circuit 5 - Galley Receptacles
Circuit 6 - Galley Lights (I might use the Reading Lights so I don’t have to wire a switch in )
9) All these Circuits will be run through the PD4000 and through ATC-style Automotive fuses
10) All the 12V circuits neutral side will come back to a common ground bar and the wired directly to the Neutral battery lug. Is that correct?
(I have links to almost everything that I wanted to make hyperlinks but I am not sure how to do that, if you are wondering about any of the specific products I will gladly post the link)
Questions:
1)How is the Rocker Switch installed? My walls are only ⅞” thick and the switch is 1.25” deep behind the plate.
2) Should it just stick out of the wall? Do I need to buy different switches?
3)Suggestions on what kind of battery and where to buy?
4)Do I ground the battery directly to the trailer or the PD4000?
5)If you suggest 12 gauge wire for the 12V receptacles, do you just strip Romex so it is 3 individual wires and go from there?
6)For the neutral side of the 12V system, does the common ground bar go to the PD4000 or to the battery?
7)Am I horribly wrong in any area? All areas?
I apologize for the wall of text but I would really appreciate it if any of this is looked through and critiqued. I also hope this can be of some help to someone out there. All the best
