Grounding power panel and power inlet "safety ground" to chassis & metal skin is common.... Some people fear it is a problem and argue against it but they are wrong.... As some people do not understand it is a safety issue for their protection... The reason for grounding frame/skin being if you are standing on wet earth and some fault in electrical system causes the skin to be HOT" (and thoroughly insulated from earth) it should protect you from getting shocked if GFCI fails to trip (wired incorrectly of defective) if GFCI works properly you may get a instantaneous bite but not lethal and if GFCI trips or is tripped it is a indicator you have electrical issues in trailer that needs your attention...
If GFCI pops when you plug into it it means you have a wiring fault some where in "device" (trailer) that you are plugging into protected receptacle... Do quick search on GFCI outlet/concept and you will begin to understand why it trips and where to search for problem.... Generally it will be a irregular path between AC hot wire and neutral... Grounding chassis and receptacle (power inlet) to extension cord safety ground should not be issue, but it may also be indicator there something else is at fault in (device) trailer...
Procedure may be to disconnect (open breaker) each one of the branch circuits in trailer (one at a time) till you can plug into GFCI receptacle and the GFCI unit does not trip then you can investigate the last branch circuit you disconnected (that tripped GFCI) to locate fault....
http://hyperphysics.phy-astr.gsu.edu/hb ... c/gfi.htmlAlso a tool to learn to use and trust is a receptacle tester with GFCI test button, always test receptacle in camp ground before plugging in umbilical to trailer....
http://www.ttbservices.com/tools/gfci-c ... tester.jpgDale
