GuitarPhotog wrote:I looked at the Perko connectors but they aren't 100% reverse-polarity proof. You can make contact on both conductors if you insert the connector improperly. This issue caused me to simply hang a pigtail with two MC4 connectors out the bottom of the trailer. I also thought it would be easier to waterproof a 1/2" hole in the floor than a 1" hole in the side of my all aluminum trailer.
My $0.02 worth
<Chas>
H.A. wrote:tony.latham wrote:I use a Perko marine deck connection.
One thing to be aware of using this Perko and similar connectors, Its not an inlet.
The pins of that plug may be energised anytime the solar module is exposed to light.
Short circuiting solar modules generally wont hurt them (small capacity arrays only...).
But whatever the short circuit was created against might be harmed by arcing or heating.
As well any unintended sparking is generally a bad idea anyway.
Further that connector is not completely foolproof against making contact in reversed polarity.
be careful...
Edit, Voltage drop is a boogieman in low voltage systems. Especially so in charging low batteries during the best daylight hours.
But really depends on ones opinion of 'good enough'.
Anyway irks me knowing a portion my expensive solar power is getting lost in the wiring before it reaches my battery or lightbulb.
I suggest 12awg or perhaps larger for solar module extension cords.
GuitarPhotog wrote:The Perko can fault because the small pin can go into the large hole, and if the frame is grounded and the large pin contacts that, you have a crossed connection at best or a short circuit at worst. Search the boating forums for opinions on the Perko. I thought it was a good idea at first but research caused me to decide differently. Your decision may be different from mine.
<Chas>
